Pro Art Models - PAU-35055 - US MRAP Radio set
Postprzez hliu24 » 20 cze 2013, 07:15
Pro Art modern US MRAP radio set
http://www.proartmodels.be/productgalle ... l_055.html
It was very hard to shoot the detail, the reflection of light from the resin's insane.... best shots I got. The details on the resin are very very fine and delicate, the pictures I shot here can't represent the really thing, you will see it when you have the really thing.
Only question to me is the main Duke box(the shape)looks deferent than most REF pictures on the internet? new version?
Chris Green's MATV walk around:
http://www.armorama.com/modules.php?op= ... artid=4093
Jay
hliu24
Dołączył(a): 03 kwi 2013, 18:30
Re: Pro Art Models - PAU-35055 - US MRAP Radio set
Postprzez kubisz » 20 cze 2013, 08:13
Świetny mały zestaw, nie tylko do M-ATV. Prawie wszystko można wykorzystać w modelach Humvee. Małe kompendium co jest co:
Great little set, not only for M-ATV. Almost everything can be used in Humvee models. Little know-how what is what:
A - klimatyzator M-ATV / M-ATV airco unit
B - DAGR z adapterem / DAGR with adapter
C - radio AN/VRC-104(V)3
D - radio AN/VRC-110
E - monitor BFT / BFT screen
F - wzmacniacz RF-5833H-PA002 / RF-5833H-PA002 power amplifier
G - komputer BFT / BFT CPU
H - ?
I - ?
J - radio AN/VRC-103
K - skrzynka kontrolna Duke / Duke control unit
L - klawiatura BFT / BFT keyboard
A:
B:
C, F:
D:
E, L:
G:
H:
J:
K:
Źródła zdjęć m.in.:
http://armorama.kitmaker.net/modules.ph ... ge=1&ord=1
http://www.prc68.com/I/DAGR.shtml
http://humvee-models.com/viewtopic.php? ... =30#p15438
http://humvee-models.com/viewtopic.php? ... 043#p20043
http://humvee-models.com/viewtopic.php?f=32&t=479
hliu24 napisał(a):Only question to me is the main Duke box(the shape)looks deferent than most REF pictures on the internet? new version?
Yes, Jay - this Duke box looks different, than at all photos known to me. I don't know why :? Also DAGR looks different, so I'm not sure if this is DAGR indeed.
Tak, Jay - ta skrzynka Duke wygląda inaczej, niż na wszystkich znanych mi zdjęciach. Nie wiem dlaczego :? Ponadto DAGR wygląda inaczej, tak więc nie jestem pewien, czy to jest rzeczywiście DAGR.
Postprzez makinen » 20 cze 2013, 08:43
Jakkolwiek ta skrzynka DUKE wygląda, to i tak jest lepsza, niż robiona własnoręcznie :gut:
Postprzez kubisz » 20 cze 2013, 08:53
Gdyby w komplecie była antena BFT, byłoby jeszcze lepiej. A tak jest całkiem nieźle, cena 12€ nie jest jakoś bardzo odrzucająca. Oprócz elementów A i H wszystko można wykorzystać w Humvee, a jest tego (radiostacji) na 3 pojazdy, w tym 1 z BFT. No i skrzynka Duke'a. Oczywiście brakuje drobnego oporządzenia, takiego jak np. słuchawki czy głośniki, ale z tym jakoś można sobie poradzić. Po raz pierwszy w przypadku wyrobów PAM nie mierzi mnie stosunek cena/zawartość.
Postprzez hliu24 » 20 cze 2013, 17:59
I is the part of the duke system, in the second duke picture, the small one on the right, it nomally mounted on the right top corner of the humvee........H I guess it is part of the new duke, feel like the new duke annena could be part of it-just guessing.
Jay
Ostatnio edytowano 20 cze 2013, 18:39 przez hliu24, łącznie edytowano 1 raz
hliu24
Postprzez Robroy1 » 20 cze 2013, 18:17
makinen napisał(a):Jakkolwiek ta skrzynka DUKE wygląda, to i tak jest lepsza, niż robiona własnoręcznie :gut:
Zgadzam się, dlatego czekam na swój zestaw- jest w drodze :)
kubisz napisał(a): Oczywiście brakuje drobnego oporządzenia, takiego jak np. słuchawki czy głośniki, ale z tym jakoś można sobie poradzić. Po raz pierwszy w przypadku wyrobów PAM nie mierzi mnie stosunek cena/zawartość.
A to nie rozwiązuje problemu? Nada się ten zestawik? :)
http://www.luckymodel.com/scale.aspx?item_no=LRE35029
Robroy1
Dołączył(a): 24 maja 2012, 17:24
Postprzez hliu24 » 20 cze 2013, 20:57
Hi, kuba
Dagr is the same, pro art put the mount and the input jack on the resin. I looked at chris green's walk around carefully, the smaller duke box( may be it is manual switch) is on there, I hope pro art didn't alter the shape of duke box to make it fix the MATV, it looks way too long, hopefully this is the new version, otherwise, scratch build if have to.
Jay
hliu24
Postprzez kubisz » 20 cze 2013, 21:28
Nie. Chodzi np. o taki głośnik i taką słuchawkę.
hliu24 napisał(a):Dagr is the same, pro art put the mount and the input jack on the resin. I looked at chris green's walk around carefully, the smaller duke box( may be it is manual switch) is on there, I hope pro art didn't alter the shape of duke box to make it fix the MATV, it looks way too long, hopefully this is the new version, otherwise, scratch build if have to.
Thanks for infos about DAGR.
Duke - so if this device with lot of swithces is a Duke controller, so maybe the best way is put it in M-ATV and save the big one for a Humvee :gut:
Postprzez hliu24 » 20 cze 2013, 21:52
yeah, man, steve said sometimes they put the dukc box on the back rack of the mAV.
I will try to put that into the m1151 and compare it to the REF picture tonight.
Jay
hliu24
Postprzez hliu24 » 21 cze 2013, 02:38
Hi Kuba
If you can match the radios and antennas that will be great, i am still not sure about those. :salut:
Thx
Jay
hliu24
